On filament sensor - wrong behavior
Printer Model: Tronxy X5SA 500
MCU / Printerboard: Spider V2.2
klippy.log is 0kb ?
moonraker (4).log (13.4 KB)
printer (8).cfg (14.5 KB)
Wanted to run out some rest filament, but on fila end sensor, the behavior is wrong
It is a stop with deactivating the drivers.
x/y drive to max, z drops on power off, fan of printerpart does run on 100%
Do I need to change the “pause” in the printer.cfg?
can’t find the point of intervention
Thanks for any help.
will that be my workaround?
You probably need a pull-up (^) on the trigger pin of the sensor.
