contained in a specifc file and “included” in the config.cfg file
it works, so if the “switch” is triggered the machine pauses and resumes if you click on “resume”
BUT
when it resumes I have a shift of the Z of a layer, which means that it does not work at all
moreover the system is far too sensitive, the slightest trigger of a few micro seconds and it pauses! , there must be a way to add a delay to the sensor? (it does not pause on its own while the filament is present)
to know that my printer is perfectly adjusted and absolutely never misses a single step
2A “large” motor, tmc2209 in uart, mks Lgen 1.0, and of course klipper mainsail :), core XY configuration
