Printer Model: Phoenix, (Own design, own build)
MCU / Printerboard: Fujitsu Futro mini pc / Octopus V1.1
klippy.zip (3.8 MB)
filament_change.zip (1.4 KB)
pause.zip (1.3 KB)
There is something wrong when you are using Pause and combining it with runout sensor detection, just resuming a lot, you make twice Pause, doesn’t matter if you set the pause on runout to true or to false, always make Pause, having or not , another defined pauses, in any case, Pause is executed twice if you have the:
pause_on_runout: False # True # 20241108
activated, and even if not, the system makes a Pause anyway, and again, when you unload the filament, you cover and uncover again the filament sensor, and makes twice too the Pause procedure, this is how I have my sensor defined, and I will enclose my Pause command, and my filament load unload routines, this is the complete filament runout setup:
# Sensor de filamento
[filament_switch_sensor filament_sensor]
runout_gcode:
M118 Detectada falta de filamento!
M118 Pulsa para descargar!
M117 Detectada falta de filamento!
M117 Pulsa para descargar!
# Pause # Tratando de evitar doble pausa 20241108
# M118 Envia el texto al terminal, M117 envia el texto a klipper screen
_LED_ROJO
# making some noise
M400 # Pausa hasta que todas las acciones pendientes se completan
M300 S440 P200
M300 S660 P250
M300 S880 P300
M600
# filament_unload # deshabilitado para que no descargue filamento dos veces seguidas
insert_gcode:
M118 Preparada para cargar filamento!
M117 Preparada para cargar filamento!
LOAD_FILAMENT
BEEP
event_delay: 3.0
pause_delay: 2.0 # 1.5 # 0.01 # 20241022
switch_pin: !PG12
