The nano is in the same USB, bute klipper cant connect to it, getting error:
mcu 'nano': Unable to connect Once the underlying issue is corrected, use the "FIRMWARE_RESTART" command to reset the firmware, reload the config, and restart the host software. Error configuring printer.
a question, is there any way to connect a arduino to the usb mcu? i tryed first with arduino esp32 sended by usb port macro comands like open or closeand got permision denied error…
also i read something like a back door comand in the printer.cfg
now im trying with arduino nano to put it like second mcu, olso having some problems with build and flash the nano getting error :
Flashing out/klipper.elf.hex to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 via avrdude
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x42
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x54
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x42
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x45
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x44
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x20
avrdude done. Thank you.
make: *** [src/avr/Makefile:34: flash] Error 1
>>>>>> Flashing failed!
Too much time to see a 15 min. video the solution is so simple, first you need to flash the Arduino Nano, or which ever, with klipper firmware generated for the microcontroller in the board, once done you need to look for the serial channel, you need to define it, and that’s all, you can see a recent example with a Ramps board, on my Github:
Flashing failed!
and the reason i think is beacuse klipper dosent know to comunicat with CH340 by USB with arduino…on pc i installed CH340 driver to comunicate with Nano
It’s not because of the driver, what you need in your case is a programmer, if you look at my Github you could see the picture of a programmer, I recommend you to use the “Arduino as ISP” programmer, you can do it simply loading a program to an existing Arduino, then you need to connect 6 wires to your Arduino Nano, using the ICSP 6 pins interface on it, and then programm it resuming, an Arduino as programmer connected via USB, and then six wires to your target Arduino, the first will program the second following your orders:
