Ashen
March 22, 2024, 9:29am
1
Printer Model: Creality CR-10 V2 with bltouch
MCU / Printer
klippy (1).log (3.3 MB)
board: atmega2560 / Printerboard: Creality 2.5.2
When running two webcams (Logitech C920 via USB + PiCam 2) on my RPI 3B with a Klipperscreen, the connection gets interrupted during printing. All runs well if I only use the PiCam2. Is the RPI hardware causing this propably?
gaolst
March 22, 2024, 10:03am
2
Most probably you drawing too much current.
You can try to add external USB Hub with external power and connect cameras there.
Sineos
March 22, 2024, 10:21am
3
Sometimes a hub helps.
General experience is that USB webcams can be (in fact, are) problematic in Klipper. Exact reason is unknown:
Too much current
Too high data rates
Other effects that causes timing issues on the USB bus
The effect is often depending on the camera model.
