Creality 4.2.2 i2c1 issue
Printer Model: Ender 5 Pro
MCU / Printerboard: 4.2.2 STM32F103
klippy.log (281.3 KB)
I’ve done my 2nd install of klipper, 1st was on a ramps 1.4 that’s working perfectly.
However, the 2nd is on a Creality 4.2.2 board. This gives me the below error when loading up:
pins.error: pin PB7 is reserved for i2c1
It seems that either klipper or the board is holding onto the i2c pins and not allowing them to be used.
Anyone have any thoughts on how to get around this?
I’ve done 3 clean installs already…same thing.
Thanks
Your Klipper version is modified.
Try a pristine Klipper version and also reflash your board with it.
I tried to disable i2c. I’ve tried with a clean install(unmodified) and it’s exactly the same result…
Well, it is a common board and probably thousands Klipper installations are running on it, so likely something is messed up on your side.
I will do another fresh install now and report back.
I guess you are on the right path “i2c1”!
To which pins is your MPU9250 on your Creality 4.2.2 board connected?
Good luck, hcet14
…I forgot that was in the config…that’s probably activating i2c1 and causing the conflict…I’ll test that now
So my i2c accelerometer from my other printer got copied across and was causing the issue :roll_eyes:
Thanks for pointing that out!
