Creality k1-Max extruder temperature
Printer Model: creality k1-max
MCU / Printerboard:
Hi, I am new in Klipper, and very bad in programming…
My question: I have rooted my k1_max and installed fluidd following Guilouz instructions. The aim is to be able to work with filaments that melt at low temperatures (less than 110C).
the printer config forces me to 180C minimum, and I tried to add the " min_extrude_temp 80" but this do not work. Please, could you make a macro " M302 S80" or something like ?
I am desperate, I need it to print professional design.
Thanks,
henri
Hello @henritelemark !
Where is it?
grafik
klippy.log (2.0 MB)
Is it the info you want ?
@henritelemark I am sure the Creality custom Klipper code controls that part.
Note you will not get any support in the Klipper group because Creality’s Klipper was developed by them and doesn’t contribute to the Klipper community.
In Discourse do a search for Creality, find forum.creality.com and add that group and post your questions there.
anyway, I am sure this is a little thing to change, but don’t know where. I recently bought this machine to replace an CR2020 (creality) that made perfectly the job but failed… I need this option.
And thanks for your advice to join Discourse :wink:
