I posted about this over on Reddit and it was recommended that I posted here. Here is the reddit link to see some of the discussion that has already happened:
I tried reading the documentation and I couldn’t find a clear answer to what I’m trying to do. Basically, I have the need to control an Arduino with Klipper but I can’t just make it another MCU.
I need to send the Arduino basic information for it to use from Klipper. Let’s say the Arduino needs to know the temperature of the extruder and a start signal for a process. I need Klipper to send the current temperature and start signal to the Arduino via I2C, SPI, or UART.
The idea is to use the Arduino as a custom controller for standalone sub-processes. One recent process I have requires eight thermocouples and four heaters with cascading PID loops. In order to do this I need a custom circuit board with firmware written to handle the specific process.
This is just one example, I’ll actually need to transfer quite a few different variables to and from the Arduino. Some of these will be process variables and others will be custom-defined. Is this possible? Thanks!
