DaVinci 2.0 A Duo: ADC out of range
Hello. I also have a Davinci 2.0A Duo(J37 pin reset version). I had the Repetier firmware, yesterday I flashed Klipper and used this configuration file. I get the following error:
Klipper reports: SHUTDOWN
MCU ‘mcu’ shutdown: ADC out of range
Sensor ‘extruder’ temperature -95.278 not in range -20.000:400.000
Sensor ‘extruder1’ temperature -144.223 not in range -20.000:400.000
This generally occurs when a heater temperature exceeds
its configured min_temp or max_temp.
Printer is shutdown
Any help please?
Hello @gtspss !
Any klippy.log please?
Check for disconnections in the wiring. Correct pins.
Thank you for the prompt answer. I have modified the temperature limits for testing purposes and that way everything works fine except the temperature measurement of the extruder sensors (not a wiring problem, before this everything worked fine). I now have the stock dual extruder but will be replacing it with a single E3D bowden extruder mod. I’ll post my progress on this in case I can help other users who want to do the same conversion.
This is probably the thermistor definition. You can DM me here or on Discord same name, and I can help with it.
sensor_type: DaVinci_e0
pullup_resistor: 4700
