Davinci mini w+ Firmware Upload Done and then no communication over USB
hallo, i wont stack firmware klipper on orginal pcb from XYZPrinting Davinci mini w+ but any time when is done USB communication is death.
On menuconfig I’m check SAM4e8e the same what is on Board.
davinci@davinci:~/klipper $ make
  Creating symbolic link out/board
  Building out/autoconf.h
  Compiling out/src/sched.o
  Compiling out/src/command.o
  Compiling out/src/basecmd.o
  Compiling out/src/debugcmds.o
  Compiling out/src/initial_pins.o
  Compiling out/src/gpiocmds.o
  Compiling out/src/stepper.o
  Compiling out/src/endstop.o
  Compiling out/src/trsync.o
  Compiling out/src/adccmds.o
  Compiling out/src/spicmds.o
  Compiling out/src/i2ccmds.o
  Compiling out/src/pwmcmds.o
  Compiling out/src/buttons.o
  Compiling out/src/tmcuart.o
  Compiling out/src/neopixel.o
  Compiling out/src/pulse_counter.o
  Compiling out/src/lcd_st7920.o
  Compiling out/src/lcd_hd44780.o
  Compiling out/src/spi_software.o
  Compiling out/src/i2c_software.o
  Compiling out/src/sensor_lis2dw.o
  Compiling out/src/thermocouple.o
  Compiling out/src/sensor_adxl345.o
  Compiling out/src/sensor_angle.o
  Compiling out/src/sensor_mpu9250.o
  Compiling out/src/atsam/main.o
  Compiling out/src/atsam/gpio.o
  Compiling out/src/atsam/i2c.o
  Compiling out/src/atsam/spi.o
  Compiling out/src/generic/armcm_boot.o
  Compiling out/src/generic/armcm_irq.o
  Compiling out/src/generic/armcm_timer.o
  Compiling out/src/generic/crc16_ccitt.o
  Compiling out/src/atsam/sam4_usb.o
  Compiling out/src/atsam/chipid.o
  Compiling out/src/generic/usb_cdc.o
  Compiling out/src/atsam/hard_pwm.o
  Compiling out/src/atsam/sam4e_afec.o
  Compiling out/src/atsam/sam4_cache.o
  Compiling out/src/../lib/sam4e/gcc/system_sam4e.o
  Building out/compile_time_request.o
Version: v0.12.0-9-gbb4711c5
  Preprocessing out/src/generic/armcm_link.ld
  Linking out/klipper.elf
  Creating bin file out/klipper.bin
davinci@davinci:~/klipper $ ls /dev/serial/by-path/*
/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0
davinci@davinci:~/klipper $ make flash FLASH_DEVICE=/dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0
  Flashing out/klipper.bin to /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0
Entering bootloader on /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0
Device reconnect on /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0
lib/bossac/bin/bossac -U -p /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0 -e -w out/klipper.bin -v
Erase flash
Done in 2.458 seconds
Write 27148 bytes to flash (54 pages)
[==============================] 100% (54/54 pages)
Done in 0.413 seconds
Verify 27148 bytes of flash
Verify successful
Done in 0.443 seconds
ls: cannot access '/dev/serial/by-path/*': No such file or directory
and klipper.log
klippy(1).log (53.7 KB)
i’m try out on the usb ids vendor ID and device ID change on the what lsusb tell me with no result.
how can i configure that USB is on Pin 136 and 137 because on the photo see
https://drive.google.com/file/d/193d-4Lvj4RpLrum07LdkEwxlSfbS3cWJ/view?usp=drive_link
Printer Model: xyzprinting Davinci mini w+
MCU / Printerboard: Orginal
