Printer Model: DIY Delta
MCU / Printerboard:Bigtreetech Tango V1.1
Host / SBC Rasberry Pi
klippyDelt.log (1.0 M)
I’ve had this printer up and running for close to 10 years now. I recently did a rehaul on it. New belts new effector and new bed. Now for the life of me, I can’t get the delta calibrate to work accurately. I’ve checked every bolt and nut to make sure everythings tight and not moving. I’m running manual calibrate with a paper trying to be very precise on now much pull there is on the paper and not touching the bed at all while I do this.
Very consistently, the head will not move parallel to the bed. After my latest calibration, when I bring the nozzle close to the bed, .7mm at the centre, and bring it closer to the front it raises. At x10.45 and Y 69.09 I have the nozzle very close almost touching the bed. At X10.45 and Y 205.9 it is a solid 4 mm from the bed. I’ve been trying to get this calibrated for 3 days now. I always get very similar results.
I used a big carpenter’s square to make sure the bed is square with the towers, I measured everything carefully to enter good values before starting calibration.
edit: I found a loose endstop. I thought I had it licked. No Joy. I recalibrated with the exact same results.
One thing I did notice. Endstop B is always around 7 mm different in my calibration results. In actuallity masuredy by a caliper from the top of the frame, they are all within .5mm. I went through several config backups and found endstop B always off by about the same amount.
