Delta DIY Probe Delta Automatic problem
When i have run Probe Delta Automatic the hotend dont go parrlel with the bed. in the middle it raise the Z azis and when Y and X are moving the hotend goes down in the bed any ideas why ?
Hello @jmsjms !
It would be way more easy to help you, if you wouldn’t have deleted the template that was there when you opened this thread.
It asked for the klippy.log.
Please attach it to your next post.
Klipper log.txt (1.6 MB)
Hi now there is a log file
I’m by no means a delta expert, but it sounds like the needed calibration was not done or not done correctly.
Alternatively, make sure that:
  • Each individual axis is running freely without binding and bumps (disconnect effector and belt to really test it)
  • Your endstops are as precisely aligned as possible
