Delta Printer Bed Crash Issues
Printer Model: Custom Delta Printer
MCU / Printerboard: BTT SKR3
Host / SBC BTT-CB1
klippy.log (5.5 MB)
Delta printer is crashing into the bed after 2nd print
Related build info:
Custom delta (manufacturer is me)
No Z probe, manual probing only
BTT SKR3 + BTT CB1 Just reflashed with Debian 12 and did a clean install of Klipper/mainsail/moonraker
Using Orca Slicer
This printer has been working fine for 2 years, decided to upgrade to get Debian 12 as the repos were discontinued for Debian 11 and I couldn’t update some things.
I copied my printer.cfg and restored it after full firmware reinstall. All kinematics, settings, etc seemed to be restored and working well.
I added a PRINT_START macro that lowers the hotend to Z25 before the print starts due to orca making a horizontal move as a first move, which is not possible for a delta when the hotend is raised to the top.
Now, I can turn the printer on, print something, and it completes fine. If I then start a second print, it will heat, then move to the bed and crash into it.
If I turn the printer off, then back on, I can start another print and it will print fine.
Additionally, my END_PRINT macro has G1 X0 Y0 Z230 F3000 because if I don’t move the effector back to the top at the end of the print before I run G28, the hotend gets sent down into the bed full force. this issue was present before I reflashed, but may be a clue as to what may be going on in the backend?
[homing_override] was added so steppers dont skip when running G28 at the homed position for tmc2209 sensorless homing.
Is there something that may have been added in an update of Klipper/mainsail/orca/something else that would cause a probe/bed/offset to be changing at the second print like this? Or did I mess something up?
Here is the GCode file: https://pastebin.com/dbM6SCUA
I have not found a single thing that seems like it could be related to these issues anywhere in the printer.cfg, or slicer/gcode. I’m at a complete loss here.
Hi
I did look at your klippy.log - I did see there 16 startups of a klipper, 11 Attempts to print something.
Also I did try to look at your sample GCode file - but it’s already absent on pastebin, archive it and upload it in this chat.
In General, if analyze last 2 attempts to print something (log line numbers 13252 and 13536 ) I see that during those attempts your klippy configuration didn’t have “PRINT_START” and “PRINT_END” macros at all, also I didn’t see any errors about those commands are unknown - so I’m assuming your GCode file is not invoking them at all.
In this scenario only “homming_overide” have some meaning - but it contain normal commands which shouldn’t produce described behavior at all, so most probably your GCode file contain some kind incorrect starting and ending sequence of commands.
So I would suggest to do following:
  • Prepare desired config and save it
  • Do full restart of a printer
  • Fully Reproduce issue
  • Collect klippy.log file and used GCode files
  • Upload fresh data to this chat
When fresh data will be collected and presented - probably we can solve this issue.
Good luck.
