Display_template for fan control
Using the quite new display_template feature for fans, I have created a fan control for my electronics bay.
It works similar to what is known from today’s PC mainboards, i.e. you set some temperature interpolation points with a corresponding fan power and the template constantly evaluates this and controls the fan depending on the readings of a sensor in the electronics bay.
[display_template FAN_BAY]
text:
    # This is the sensor object of the thermistor used to control the fan
    {% set temp = printer['temperature_sensor electronics_bay'].temperature %}
    # Set the interpolation points here:
    {% set points = [
        [0, 0.3],
        [35, 0.3],
        [50, 0.5],
        [60, 0.8],
        [61, 1.0]
    {% if temp < points[0][0] %}
        { "0.0" | trim }
    {% else %}
        {% if points|length > 0 %}
            {% set value = 0 %}
            {% for i in range((points | length) - 1) %}
                {% set t1, v1 = points[i] %}
                {% set t2, v2 = points[i + 1] %}
                {% if t1 <= temp < t2 %}
                    {% set value = v1 + (temp - t1) * (v2 - v1) / (t2 - t1) %}
                    { value | round(3) | trim }
            {% endfor %}
            {% if temp >= points[-1][0] %}
                {% set value = points[-1][1] %}
        {% else %}
            { "0.0" | trim }
## Cooling Fan of the electronics bay
[fan_generic electronics_bay]
pin: !PD14
max_power: 1
shutdown_speed: 0.0
cycle_time: 0.00004
[temperature_sensor electronics_bay]
sensor_type: Generic 3950
sensor_pin: PF4
# Start the electronics bay fan control
[delayed_gcode _START_BAY_FAN]
initial_duration: 1.
  SET_FAN_SPEED FAN=electronics_bay TEMPLATE=FAN_BAY
The settings above give a control curve that looks like:
