My printer identifies itself as a jet aircraft
Printer Model: SV08max
MCU / Printerboard: SV08MAX/Motherboard/Mcu_Pin_definition.pdf at main · Sovol3d/SV08MAX · GitHub
Hi everyone,
I received my 08max, but unfortunately it is SO INCREDIBLY loud that you can’t work next to it. This is due to the fans for the motherboard and the heating bed control.
For the motherboard, I will use a slow, large fan. The fan for the heating bed control arrived defective, so I want to use a bigger 4-pin PWM fan.
The fan pin is K_Fan3 and it is a PWM-controllable fan.
This should now be adjusted to the MCU temperature: e.g. 45 degrees, 25%, 50 degrees, 50%, etc.
Unfortunately, I’m new to Klipper. I know a little bit of C+ for Arduino, but I really have no idea how to get started with this.
Do you think you can help me?
All the documents are stored here: SV08MAX/home/sovol/klipper at main · Sovol3d/SV08MAX · GitHub
Of course, I’ll be happy to help and find the information you need!
Hi @Calmato67 ,
You might want to take a look here at a custom fan template.
