Doboz Mooz + Bigtreech Octopus Pro
Printer Model: Dobot Mooz 2
MCU / Printerboard: Octopus Pro
Hello,
I have a dobot mooz 2 3d printer with a burnt motherboard.
Here is information about the product: https://www.youtube.com/watch?v=YCAmSi8TwzA
After the product’s motherboard was burned, it sat idle for a while. Now I bought a Bigtreech Octopus Pro motherboard and rewired it. I used TMC 2209 drivers as stepper drivers.
I also had a problem with the product’s own extruder and I bought this product instead.
Here is the Extruder: Ender 3 Alüminyum Extruder Blok Seti Kırmızı - Rhino3D Printer
I had a hard time adjusting the config settings of this product. I’m a novice at this. Thank you very much to anyone who can help or guide me.
Hello @epiktetos87 !
Please attach the klippy.log to your next post.
Hello,
I lost a lot of progress while I couldn’t access the forum. In the printer.cfg file I shared, step calculation and printer dimensions are now correctly determined. I added Bltouch. The problem I’m having right now is that when I homing, the x and y axes are homing without any problems. However, on the z axis, bl touch remains where it is without moving at all and accepts the current location as “0”.
printer.cfg (6.1 KB)
klippy.log (2.7 MB)
Why do you have a virtual_endstop for Z1?
When you do z-homing with a probe, there is only one virtual_endstop and also no additional endstop_pins. And also not on stepper_z.
It should be
Please read here:
https://www.klipper3d.org/BLTouch.html
Thank you for your help. I will test it as soon as possible and get back to you.
