EBB36 fans not working
Printer Model: Voron 0.2r1 (Formbot Kit)
MCU / Printerboard: BTT SKR Pico
Host / SBC: BTT Pi
logs-20250523-103717.zip (62.9 KB)
Hello, I’m trying to get my fans connected to my EBB36 V1.2 to work.
All the other connected components are working (extruder, heater, etc.) except my two fans.
I can’t figure out why. Does anyone have any idea? Thanks!
Here is my ebb36.cfg config :
[mcu EBBCan]
canbus_uuid:290b5aafc145
[adxl345]
cs_pin: EBBCan: PB12
spi_software_sclk_pin: EBBCan: PB10
spi_software_mosi_pin: EBBCan: PB11
spi_software_miso_pin: EBBCan: PB2
axes_map: x,y,z
step_pin: EBBCan: PD0
dir_pin: !EBBCan: PD1
enable_pin: !EBBCan: PD2
microsteps: 32
full_steps_per_rotation: 200
rotation_distance: 22.23
nozzle_diameter: 0.400
filament_diameter: 1.750
gear_ratio: 50:10
heater_pin: EBBCan: PB13
sensor_type: Generic 3950
sensor_pin: EBBCan: PA3
control: pid
min_temp: 0
max_temp: 280
min_extrude_temp: 170
max_extrude_only_distance: 150
max_extrude_cross_section: 0.8
pressure_advance: 0.05                                               # See tuning pressure advance doc
pressure_advance_smooth_time: 0.040
[tmc2209 extruder]
uart_pin: EBBCan: PA15
run_current: 0.5
stealthchop_threshold: 0
[fan]
pin: EBBCan: PA1
[heater_fan hotend_fan]
pin: EBBCan: PA0
heater: extruder
heater_temp: 50.0
