EBB36 third Fan
Printer delta
MCU / duet wifi:
I would like to hook up a third fan to the ebb36 that can be controlled buy klipper, but can’t figure which pin’s to use or if i can. any one have any suggestion? i have 12 and 24v fans
That board only has 3 mosfets, and 1 is typically used to control the heater for the hotend. If you are running a heater with the board, then you can only control 2 fans.
