Printer Model: BLV mgn Cube
klippy (2).log (121.6 KB)
MCU / Printerboard: Octopus f446
Host / SBC OrangePi
Please help, ebb42 is on my head, I bought a cartographer (or rather, a clone from IDM), connected everything according to the instructions docs.cartographer3d.com but if I connect the cartographer, the printer does not start at all, everything is fine without it, I can’t get the canbus_uuid of the cartographer either, it gives an error
mcu ‘EBBCan’: Unable to connect
Error configuring printer
File “/home/orangepi/klippy-env/lib/python3.9/site-packages/can/interfaces/socketcan/socketcan.py”, line 679, in _send_once
sent = self.socket.send(data)
OSError: [Errno 105] No buffer space available
File “/home/orangepi/klipper/scripts/canbus_query.py”, line 64, in
main()
File “/home/orangepi/klipper/scripts/canbus_query.py”, line 61, in main
query_unassigned(canbus_iface)
File “/home/orangepi/klipper/scripts/canbus_query.py”, line 25, in query_unassigned
bus.send(msg)
File “/home/orangepi/klippy-env/lib/python3.9/site-packages/can/interfaces/socketcan/socketcan.py”, line 658, in send
sent = self._send_once(data, msg.channel)
File “/home/orangepi/klippy-env/lib/python3.9/site-packages/can/interfaces/socketcan/socketcan.py”, line 681, in _send_once
raise can.CanError(“Failed to transmit: %s” % exc)
can.CanError: Failed to transmit: [Errno 105] No buffer space available
sudo ifconfig -a
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 128 (UNSPEC)
RX packets 1124 bytes 8046 (7.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 188 bytes 894 (894.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
