Hola, he instalado klipper sobre un pc, y ahora toca instalar el fichero printer,. He repasado varios ficheros pero no doy con el apropiado. La impresora es una ender 3 reformada con placa 4.2.7 y con cr touch y Sprite pro kit de creality. ¿ cual seria la configuracion idonea para imprimir correctamente, y a la vez poder nivelar la cama de la misma. ? saludos
Hello, I have installed Klipper on a PC, and now I have to install the printer file. I have gone through several files but I can’t find the right one. The printer is a refurbished Ender 3 with a 4.2.7 board and with Creality’s CR Touch and Sprite Pro kit. What would be the ideal configuration to print correctly, and at the same time be able to level the bed? Regards.
