I am trying to search about using the ender 3 max neo with Klipper but I am unable to find any information about it the SBC I am using is a Libre Renegade and got everything set up on it but can’t find the firmware I need for the ender 3 max neo nor the configuration files for Klipper.
this does not work as it is not the NEO version of the config it prints off of the bed and I am unable to get it to work with my ender 3 MAX NEO I got the firmware, but the config is still the issue as I can’t find the correct one if anyone has the sonic pad to get the printer.cfg from there that would be helpful
Then you can adjust the sizes in the printer.cfg.
If no one has made a config file for the NEO before, then ![]()
Hello all,
Anyone has any success with finding a working .cfg file for Creality Ender 3 Max Neo ?
This came from a sonic pad for an ender 3 max neo. My works perfectly. I would not do an exact copy from this but probably modify the one from the Ender 3 Max or something. Hope this helps some.
# !Ender-3 Max Neo
# printer_size: 300x300x340
# version: 3.6
# This file contains pin mappings for the stock 2020 Creality Ender 3
# MAX. To use this config, during "make menuconfig" select the
# STM32F103 with a "28KiB bootloader" and serial (on USART1 PA10/PA9)
# communication.
# Because this printer has factory wiring, mounts, and firmware for
# a BLTouch, but does not ship with one at this time, default values
# for the sensor have been specified, but disabled, in anticipation of
# future revisions or user modification. User should take care to
# customize the offsets, particularly z-offset, for their specific unit.
# Flash this firmware by copying "out/klipper.bin" to a SD card and
# turning on the printer with the card inserted. The firmware
# filename must end in ".bin" and must not match the last filename
# that was flashed.
###fluidd set
[virtual_sdcard]
path: ~/gcode_files
[display_status]
[pause_resume]
[gcode_macro PAUSE]
description: Pause the actual running print
rename_existing: PAUSE_BASE
# change this if you need more or less extrusion
variable_extrude: 1.0
##### read E from pause macro #####
{% set E = printer["gcode_macro PAUSE"].extrude|float %}
##### set park positon for x and y #####
# default is your max posion from your printer.cfg
{% set x_park = printer.toolhead.axis_maximum.x|float - 5.0 %}
{% set y_park = printer.toolhead.axis_maximum.y|float - 5.0 %}
##### calculate save lift position #####
{% set max_z = printer.toolhead.axis_maximum.z|float %}
{% set act_z = printer.toolhead.position.z|float %}
{% if act_z < (max_z - 2.0) %}
{% set z_safe = 2.0 %}
{% else %}
{% set z_safe = max_z - act_z %}
##### end of definitions #####
PAUSE_BASE
G91
{% if printer.extruder.can_extrude|lower == 'true' %}
G1 E-{E} F2100
{% else %}
{action_respond_info("Extruder not hot enough")}
{% if "xyz" in printer.toolhead.homed_axes %}
G1 Z{z_safe} F900
G90
G1 X{x_park} Y{y_park} F6000
{% else %}
{action_respond_info("Printer not homed")}
[gcode_macro RESUME]
description: Resume the actual running print
rename_existing: RESUME_BASE
#### get VELOCITY parameter if specified ####
{% if 'VELOCITY' in params|upper %}
{% set get_params = ('VELOCITY=' + params.VELOCITY) %}
{%else %}
{% set get_params = "" %}
G91
G1 E{E} F2100
{% else %}
RESUME_BASE {get_params}
[gcode_macro CANCEL_PRINT]
description: Cancel the actual running print
rename_existing: CANCEL_PRINT_BASE
TURN_OFF_HEATERS
G91
G1 Z4.5 F300
G90
{% else %}
G28 X Y
G1 Y{y_park} F2000
M84
CANCEL_PRINT_BASE
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: -25
position_max: 300
position_min: -25
homing_speed: 80
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 300
homing_speed: 80
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
rotation_distance: 8
# position_endstop: 0.0 # disable to use BLTouch
# endstop_pin: ^PA7 # disable to use BLTouch
endstop_pin: probe:z_virtual_endstop # enable to use BLTouch
position_min: -5 # enable to use BLTouch
position_max: 345
[safe_z_home] # enable for BLTouch
home_xy_position: 182, 167
speed: 200
z_hop: 5
z_hop_speed: 5
[bltouch] # enable for BLTouch - fast-mode
sensor_pin: ^PB1
control_pin: PB0
x_offset: -32 # modify as needed for bltouch location
y_offset: -12 # modify as needed for bltouch location
#z_offset: 0.0 # modify as needed for bltouch or run PROBE_CALIBRATE
speed: 20
pin_up_touch_mode_reports_triggered: False
[bed_mesh] # enable for BLTouch
speed: 150
mesh_min: 23, 25
mesh_max: 268, 288
algorithm: bicubic
probe_count: 5,5
horizontal_move_z: 5
[idle_timeout]
timeout: 172800
[bed_screws]
screw1:30,25
screw1_name:1
screw2:270,25
screw2_name:2
screw3:270,270
screw3_name:3
screw4:30,270
screw4_name:4
max_extrude_only_distance: 1000.0
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
rotation_distance: 31.901
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 265
pressure_advance: 0.0
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
[fan_generic extruder_partfan]
pin: PC6
# [mcu rpi]
# serial: /tmp/klipper_host_mcu
# [adxl345]
# cs_pin: rpi:None
# spi_speed: 2000000
# spi_bus: spidev2.0
# [resonance_tester]
# accel_chip: adxl345
# accel_per_hz: 70
# probe_points:
# 150,150,10
[input_shaper]
shaper_type_x = ei
shaper_freq_x = 136.8
shaper_type_y = mzv
shaper_freq_y = 28.6
[filament_switch_sensor filament_sensor]
switch_pin: PA4
serial: /dev/serial/by-id/usb_serial_1
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 5000
max_z_velocity: 10
max_z_accel: 1000
square_corner_velocity: 5.0
[include timelapse.cfg]
[exclude_object]
[gcode_macro G29]
G28
bed_mesh_calibrate
G1 X0 Y0 Z10 F4200
# save_config
[gcode_arcs]
#resolution: 1.0
#*# [bltouch]
#*# z_offset = 2.150
#*# [bed_mesh default]
#*# version = 1
#*# points =
#*# -0.022500, -0.055000, -0.017500, -0.085000, -0.145000
#*# -0.035000, 0.020000, 0.027500, -0.045000, -0.122500
#*# 0.070000, 0.010000, -0.030000, -0.092500, -0.145000
#*# 0.075000, 0.070000, -0.007500, -0.095000, -0.170000
#*# 0.100000, -0.032500, -0.097500, -0.137500, -0.190000
#*# x_count = 5
#*# y_count = 5
#*# mesh_x_pps = 2
#*# mesh_y_pps = 2
#*# algo = bicubic
#*# tension = 0.2
#*# min_x = 23.0
#*# max_x = 268.0
#*# min_y = 25.0
#*# max_y = 288.0
Hi, did anyone come right with the print.cfg I can’t find one anywhere!
Will this help?
# !Ender-3 Max Neo
# version: 3.6
# communication.
# that was flashed.
###fluidd set
[include cx_printer.cfg]
[display_status]
[pause_resume]
[gcode_macro PAUSE]
{% else %}
PAUSE_BASE
G91
G1 E-{E} F2100
{% else %}
G1 Z{z_safe} F900
G90
{% else %}
{%else %}
G91
G1 E{E} F2100
{% else %}
TURN_OFF_HEATERS
G91
G1 Z4.5 F300
G90
{% else %}
G28 X Y
G1 Y{y_park} F2000
M84
CANCEL_PRINT_BASE
[stepper_x]
step_pin: PC2
dir_pin: PB9
enable_pin: !PC3
endstop_pin: ^PA5
position_max: 300
position_min: -25
homing_speed: 80
[stepper_y]
step_pin: PB8
dir_pin: PB7
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 300
homing_speed: 80
step_pin: PB6
dir_pin: !PB5
enable_pin: !PC3
position_max: 345
speed: 200
z_hop: 5
z_hop_speed: 5
sensor_pin: ^PB1
control_pin: PB0
speed: 20
speed: 150
mesh_min: 23, 25
mesh_max: 268, 288
algorithm: bicubic
probe_count: 5,5
[bed_screws]
screw1:30,25
screw1_name:1
screw2:270,25
screw2_name:2
screw3:270,270
screw3_name:3
screw4:30,270
screw4_name:4
step_pin: PB4
dir_pin: PB3
enable_pin: !PC3
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 265
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
pin: PC6
# [mcu rpi]
# [adxl345]
# cs_pin: rpi:None
# accel_per_hz: 70
# probe_points:
# 150,150,10
[input_shaper]
shaper_type_x = ei
shaper_type_y = mzv
switch_pin: PA4
[printer]
max_velocity: 300
max_accel: 5000
max_z_velocity: 10
max_z_accel: 1000
[exclude_object]
[gcode_arcs]
#resolution: 1.0
[include cx_gmcro.cfg]
Hello @Akcamay
Please:
Either upload your config as a file
or
Format it as preformatted text.
This way it is of no use for anyone.
Sorry about the different size font. but this came off my Ender 3 Max Neo “printer.cfg”
That’s the reason why you should upload as file or format as preformatted text.
