Ender 3 skr mini e3 v3 problem
Printer Model: ender 3
MCU / Printerboard: stm32g0b1
Host / SBC PI 4
klippy (1).log (513.7 KB)
hi grateful have followed it but am getting this error Klipper reports
: ERROR Pin ‘pc15’ is not a valid pin name on mcu ‘mcu’ Once the underlying issue is corrected, use the “RESTART” command to reload the config and restart the host software. Printer is halted have reflashes the board with the renamed klipper.bin file but still getting it don’t know where to start looking any help would be grateful![:folded_hands:
Hello @CLANKY !
You have connection issues in the log, but the issue you mention does not appear.
thanks for looking and getting back to me check this new one thanks
new klippy.log (236.2 KB)
[filament_switch_sensor switch_sensor]
switch_pin = pc15   # <------
pause_on_runout = False
runout_gcode =
	PAUSE
	M117 Filament switch runout
insert_gcode =
	M117 Filament switch inserted
Have you tried with upper case letters?
switch_pin = PC15   # <------
runout_gcode =
	PAUSE
insert_gcode =
Same here:
[filament_motion_sensor encoder_sensor]
switch_pin = pc12
detection_length = 20
extruder = extruder
runout_gcode =
	PAUSE
	M117 Filament encoder runout
insert_gcode =
	M117 Filament encoder inserted
Thanks for helping try and install the rest of the macros
