SKR 1.4 Turbo after update to 0.12: Pin 'P1.10' is not a valid pin name on mcu 'mcu'
Printer Model: Prusa i3 Bear Mod
MCU / Printerboard: SKR 1.4 Turbo
I had a perfectly working Klipper config on SKR 1.4 Turbo until I upgraded from v0.11.0-311-g9e765dae to v0.12.0-8-g187cc2f1 and suddenly started getting:
As far as I can tell this is the only pin that’s causing trouble. I use it in:
[tmc2209 stepper_x]
uart_pin: P1.10
interpolate: True
run_current: 0.800
#hold_current: 0.500
stealthchop_threshold: 999999
#stealthchop_threshold: 250
diag_pin: P1.29
driver_SGTHRS: 110
This is consistent with the example in Git repository. I tried recompiling the firmware, to no avail.
I have had many successful upgrades in the past, until today.
klippy.log (6.3 MB)
(Note that klippy.log has logs from successful startup earlier today as well as failed ones after the upgrade)
FWIW I have another, very similar printer on 0.12 and same board and almost identical config and it’s not having this issue.
Hmm, weirdly enough rebooting Raspberry Pi host fixed the issue. Sorry about the noise.
Ok, even more weird - after another Raspberry Pi reboot the issue came back. Any ideas are welcome.
Ok, finally understood this - I had second MCU attached to the Raspberry Pi which had accelerometer hooked up.
I also had:
serial: /dev/ttyACM0
which became randomly assigned to either SKR 1.4 or the second MCU.
Changing serial to use /dev/serial/by-id/ fixed the issue:
serial: /dev/serial/by-id/usb-Klipper_lpc1769_0CB00214E910D595B309DB61C42000F5-if00
