Ender 3 v2 blank screen after firmware.bin flash
Printer Model:
MCU / Printerboard:
After installing klipper (communicates with octoprint),
I changed klipper.bin to firmware.bin and placed it in the sd slot.
Powered on, but nothing on screen (except back light).
Bought a new 32gb sd card re-dowloaded klipper.bin and renamed it to firmware.bin.
Put it in sd slot, turned power on…
Nothing on screen.
Octoprint is communicating with klipper & the printer (i can extrude 100mm but it’s only moving 96mm).
I’m dead in the water.
What do i do from here?
Thanks,
D
Since you are already floating dead in the water, was it too much to provide the information as asked for during opening this request?
And while you are at it: Which kind of display?
The Ender v2 screen isn’t supported by Klipper.
So basically, you’re up and running as expected for that printer.
Yeah,
After a couple of days and many searches, I already figured that out.
Thanks for your help, I appreciate the response very much.
