Ender 6 ezabl pro
good evening I just installed Klipper on the ender 6 v4.3.1 board and I have an eazbl pro and I can’t get home.
the bed goes down, the x and y home ok but the bed does not go up to go to the Z sensor
and I am also looking for the pin diagram of the creality v4.3.1 card
Thank you
jm
Hello @kirty_one !
Can you please share the klippy.log?
hello here is the log and the printer config
thank you
jm
Downloads.zip (59.2 KB)
As far as I found out, you have to use a different pin for the EZABL.
You may have a look on this:
https://www.reddit.com/r/ender6/comments/nz1rxu/ender_6_klipper_with_ezabl_probe/
I think I found reverse PA7
[probe]
pin: !PA7
x_offset: -44.0
y_offset: -10.
z_offset: 1.0
speed: 10.0
thanks to the group
Hello,
[probe]
pin: !PA7
x_offset: -44.0
y_offset: -10.
z_offset: 1.0
speed: 10.0
thanks to the group
