Ender3 PRO with Mainboard 4.2.7 and BLtouch v.1
Hi, yesterday I installed on my Ender3 PRO with Klipper an old BLtouch V1 that I wiring with mainboard following this scheme:
When I send G29 command to the printer, I see that X and Y axis go to ZERO position and Z axis go to center of the bed, the BLtouch release the probe and when touch the bed stop, it rises and then descends again to stop after touching the plate with the probe for the second time.
At this point, though. klipper gives me this error: “BL touch failed to raise probe”.
I am writing my printer.cfg below, hoping you can help me
[include mainsail.cfg]
[include MCU_secondario.cfg]
[stepper_x]
step_pin: PB9
dir_pin: PC2
enable_pin: !PC3
rotation_distance: 40
endstop_pin: ^PA5
position_endstop: 0
position_max: 235
homing_speed: 50
[stepper_y]
step_pin: PB7
dir_pin: PB8
enable_pin: !PC3
endstop_pin: ^PA6
position_endstop: 0
position_max: 235
homing_speed: 50
step_pin: PB5
dir_pin: !PB6
enable_pin: !PC3
rotation_distance: 8
#endstop_pin: ^PA7
#position_endstop: -2.8
position_min: -3
position_max: 250
max_extrude_only_distance: 100.0
step_pin: PB3
dir_pin: PB4
enable_pin: !PC3
rotation_distance: 33.500
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PA1
sensor_pin: PC5
control: pid
pid_Kp: 21.527
pid_Ki: 1.063
pid_Kd: 108.982
min_temp: 0
max_temp: 250
[heater_bed]
heater_pin: PA2
sensor_pin: PC4
control: pid
pid_Kp: 54.027
pid_Ki: 0.770
pid_Kd: 948.182
min_temp: 0
max_temp: 130
[fan]
pin: PA0
restart_method: command
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 3000
max_z_velocity: 5
max_z_accel: 100
[virtual_sdcard]
path: ~/gcode_files
[display_status]
[pause_resume]
[bltouch]
sensor_pin: ^PA7
z_offset: 0
control_pin: PB0
pin_up_touch_mode_reports_triggered: False
probe_with_touch_mode: True
x_offset: -48
y_offset: 10
#pin_move_time: 0.0
[display]
lcd_type: st7920
cs_pin: PB12
sclk_pin: PB13
sid_pin: PB15
encoder_pins: ^PB14, ^PB10
click_pin: ^!PB2
[safe_z_home]
home_xy_position: 155,120
speed: 80
z_hop: 10
z_hop_speed: 5
[bed_mesh]
speed: 50
horizontal_move_z: 5
mesh_min: 32, 60 # add the x and y offsets for both mesh_min and max. This is set for mine.
mesh_max: 172, 210
probe_count: 3,3
mesh_pps: 2,2
[board_pins]
aliases:
EXP1_1=PC6,EXP1_3=PB10,EXP1_5=PB14,EXP1_7=PB12,EXP1_9=,
EXP1_2=PB2,EXP1_4=PB11,EXP1_6=PB13,EXP1_8=PB15,EXP1_10=<5V>,
PROBE_IN=PB0,PROBE_OUT=PB1,FIL_RUNOUT=PC6
Thanks very mutch and ciao
Remove pin_up_touch_mode_reports_triggered: False and follow the template / information provided when you opened the topic.
Thanks Sineos, the problem was the code “probe_with_touch_mode: True” (probably my BLtouch is a clone); I removed it and now all work fine.
Now I’m searching tutorials on how manual calibrate the bed and then on how use mesh bed.
If I understand right, before I must calibrate the bed manually using the paper near the four screws and then I can use the probe to compensate for small difference to level bed, right?
Thanks again and ciao
