Endstop Issues on my Ender 5 Plus - Smashing Rails on X (sometimes)
Printer Model: Ender 5 Plus
MCU / Printerboard: SKR PRO 1.2
Host / SBC Raspberry Pi 3b
Hey there,
I run in problems while homing my x axle on my ender 5 plus.
I use mechanical endstops, the sensorless homing of the tmc2209 are disabled (by bend pin).
All endstops trigger fine, query the state of each shows the expected values.
While homing x the endstops will be ignored, and mashes against the rail.
This behaviour / problem occures not within each homing sequence, mostly when homing after a print or some other movements happends before.
What i tried so far:
  • I replaced the endstop - same problem
  • when using homing sequence with two hits (homing_retract_dist > 0) first hit works (mostly) correct, while the second smashes in the rails.
  • now running with homing_retract_dist = 0 does not solve the problem.
  • Homing Y before X helps (sometimes).
I recently migrated from marlin, where printer and endstops works.
Klipper is realy great and i hope i can fix this issue.
Do you have any ideas?
Best regards Matthias
In my Logfiles attached you find the smashing rails on (Stats 4991.6)
[1]
Stats 4991.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000007 mcu_task_stddev=0.000004 bytes_write=42749 bytes_read=67714 bytes_retransmit=30 bytes_invalid=0 send_seq=2528 receive_seq=2526 retransmit_seq=2528 srtt=0.001 rttvar=0.001 rto=0.100 ready_bytes=0 upcoming_bytes=76 freq=168002262 heater_bed: target=0 temp=50.8 pwm=0.000 sysload=0.49 cputime=267.215 memavail=570816 print_time=4955.604 buffer_time=0.000 print_stall=0 extruder: target=0 temp=83.2 pwm=0.000
Unable to obtain tmc stepper_x phase
logs-20250417-160220.zip (416.5 KB)
Would be helpful to see your stepper x config as well as the driver config for x
Also are you using SET_GCODE_OFFSET anywhere ?
Hey @jsmith ,
Thanks for the quick reply! See my driver/stepper configuration below.
I did not found any usage of SET_GCODE_OFFSET.
This would be part of a macro, right?
Can I query the current GCODE_OFFSET?
Might this also be part of a gcode (als cura prefix o.e.)? what would be the coresponding G-Codes?
Thanks a lot!
[stepper_x]
step_pin: PE9
dir_pin: PF1
enable_pin: !PF2
microsteps: 128
rotation_distance: 40
endstop_pin: PB10
# https://klipper.discourse.group/t/understanding-x-and-y-axes-limits-and-homing/10779
position_endstop: 350
position_max: 350
homing_speed: 50
#https://www.klipper3d.org/Config_Reference.html#stepper
homing_retract_dist: 0
[tmc2209 stepper_x]
uart_pin: PC13
run_current: 0.800
hold_current: 0.500
stealthchop_threshold: 999999
Your endstop is on the right side assume ? If you didn’t set a gcode_offset then there isn’t one.
Try this for homing:
homing_speed: 50
homing_retract_dist: 5
homing_retract_speed: 25
second_homing_speed: 5
Edit: You can safely comment out hold_current.
Edit 2: If limit switch is on the right I would expect to see “homing_positive_dir: true” If it’s on the left side you need minimum which would be a negative number, Klipper may draw that conclusion from the max value though. I have an Idex so 2 on x Axis so I use it.
Edit 3 lol: You may need a pullup on the endstop pin IE: “endstop_pin: ^PB10”. My money is on this one because if pin floats high/low you can weird results.
Jepp, the endstop is on the right side …
I tried the config, but same issue. After (pre)heating nozzle and bed the homing failed.
This time the first hit was also ignored.
Stripped Log-File attached …
klippy.log (73.7 KB)
Edit, nm just noticed the board your using, the Klipper generic config don’t use pullups for that board. You can skip starting a print or pre-heating to trouble shoot, just issue a G28 in console to home.
At this point I would double check the wiring is solid for that endstop. I run a BTT Octopus and use pullups so the pin state can’t float. That’s with 2 wire end stops. If you have 3 wire you probably don’t need them.
With motors off (M84) move X axis to depress endstop and issue QUERY_ENDSTOPS in console. It will show the state of the endstops.:
x:TRIGGERED y:open z:open
The LOL on Edit2 was the hint! :slight_smile:
With the pullup on the endstops it’s working fine now!
Thanks for the great and super fast support @jsmith !
Awesome!
Thanks a lot!
You’re welcome
