Printer Model: Anycubic Kobra 2 MAX
MCU / Printerboard: BTT Manta E3EZ
klippy.log (469.7 KB)
Everything boots fine but when I try to home X or Y I get the error “Endstop stepper_x still triggered after retract”. The steppers don’t move at all, just a slight buzz. Wiring issue?
- The
enable pins have to be inverted.
then
- For the endstops use verify-endstops
Best is, you go through this complete document: Configuration checks - Klipper documentation
[stepper_x]
step_pin = PA14
dir_pin = !PA10
enable_pin = PA13
microsteps = 16
rotation_distance = 40
endstop_pin = ^!PC4
position_endstop = 0
position_max = 235
homing_speed = 50
[stepper_y]
step_pin = PC8
dir_pin = !PA15
enable_pin = PC14
microsteps = 16
endstop_pin = ^!PB0
position_max = 235
homing_speed = 50
step_pin = PD2
dir_pin = PD4
enable_pin = PD3
microsteps = 16
rotation_distance = 8
endstop_pin = ^!PC6
position_max = 270
step_pin = PD5
dir_pin = !PD6
enable_pin = PB3
microsteps = 16
rotation_distance = 33.500
nozzle_diameter = 0.400
filament_diameter = 1.750
heater_pin = PB11
sensor_pin = PA4
control = pid
pid_kp = 21.527
pid_ki = 1.063
pid_kd = 108.982
min_temp = 0
max_temp = 250
Sorry, where?
Is this not inverted, exactly at the Configuration Checks document says they should be?
endstop_pin = ^!PC4
endstop_pin = ^!PB0
I’m talking about the enable_pins!
Lines 4, 15, 26 & 36 in my previous post.
Ah! Sorry, sometimes these old eyes don’t read correctly the first time.
Thank you, will try that.
EDIT: it worked!
Thank you so much for helping!
