Error after updating Sonic Pad
Printer Model: Ender 3 S1 Pro
MCU / Printerboard:CR-FDM-V2.5.S1
Hi all I have done the update on my Sonic Pad the latest version V1.0.6.54.20. After the update, I had to restore to the factory settings, flash the printer to get it to work again. I started a print this afternoon and the printer just stopped.
This was the error.
“internal Error on WebRequest: query_endstops/status Once the underlying issue is corrected, use the FIRMWARE_RESTART command to reset the firmware, reload the config, and restart the host software. Printer is shutdown”
Any help is appreciated thank you
klippy.log (119.5 KB)
Hello @DanielK !
Please note this on the Sonic Pad
Did you notice in line 1119 of your klippy.log?
UnicodeEncodeError: ‘ascii’ codec can’t encode character u’\xe1’ in position 28: ordinal not in range(128)
Yes I have any advice how to rectify?
Obviously you have a non ascii character in a filename. Maybe it is an á
