Error: Option 'pin' is not valid in section 'stepper_z'
Printer Model: Kingroon KP3s
MCU / Printerboard: Kingroon (GD32F303)
klippy.log (215.3 KB)
Describe your issue: Well, I had a semi-working configuration but then encountered some problems. So I’ve redone things – as far as I know correctly – but get this “Option ‘pin’ is not valid in section ‘stepper_z’” error for what appears to be no reason. I’ve Googled this but don’t find anything that helps. The log is attached, but here’s the stepper z config:
step_pin: PB5
dir_pin: !PB4
enable_pin: !PB8
full_steps_per_rotation: 200
microsteps: 32
rotation_distance: 8
endstop_pin: !PA11 # disable to use BLTouch
endstop_pin: probe:z_virtual_endstop # enable to use BLTouch
position_endstop: 0.5 # disable to use BLTouch
position_max: 180
homing_retract_dist: 10.0
second_homing_speed: 5
position_min: -5 # enable to use BLTouch
Any help appreciated!
step_pin = PB5
dir_pin = !PB4
enable_pin = !PB8
full_steps_per_rotation = 200
microsteps = 32
rotation_distance = 8
endstop_pin = !PA11
position_endstop = 0
position_max = 180
homing_retract_dist = 10.0
second_homing_speed = 5
pin = ^!PA11        # What pin?
x_offset = -40
y_offset = 0
z_offset = 0
speed = 150
horizontal_move_z = 5
mesh_min = 30,30
mesh_max = 170,175
probe_count = 3,3
grafik
Thanks so much! Sloppy editing on my part…
