How do i exclude an object via KlipperScreen?
It would be ideal to have a GUI representation, like in fluidd, to exclude the objects, but im fine with a name-based exclude system as well.
If it isnt avaibile, how do I configure KlipperScreen.conf to add it?
Sineos
2
Check the “Cancel” dialog. Only present if there are at least two objects.
I’ll try this out when I print again! Is it the graphical method, or the name-based method? Thanks
Sineos
4
No clue, never tried. Just saw it is there.
Hey. I did a multi-object print today and I pressed the cancel button. The object’s names showed up to cancel individually. Thanks for this!
