"Extrude only move too long" during manual Resonance Compensation
Printer Model: Formbot T-Rex 3
MCU / Printerboard: Vivedino V2 - ATMega 2560
Host / SBC: Raspberry Pi 4
klippy.log: Resonance Compensation_logs.zip (2.0 MB)
Today me :slight_smile:
I tried a manual Resonance Compensation as describes here. Resonance Compensation - Klipper documentation
After setting up the printer accordingly to the Ringing frequency - section,
shortly after start I was greeted with this error message:
Extrude only move too long (-5331.738mm vs 101.000mm)
As for the serial.log, the previous commands were these (complete in the serial.log):
2025-08-18 19:28:23,611 - Send: N56 M300 S440 P500*21
2025-08-18 19:28:23,619 - Recv: ok
2025-08-18 19:28:23,624 - Send: N57 G1 X-43 F4000*42
2025-08-18 19:28:23,636 - Recv: ok
2025-08-18 19:28:23,641 - Send: N58 G1 E5 F250*20
2025-08-18 19:28:23,652 - Recv: // Extrude only move too long (-5326.625mm vs 101.000mm)
2025-08-18 19:28:23,654 - Recv: // See the 'max_extrude_only_distance' config option for details
2025-08-18 19:28:23,655 - Recv: !! Extrude only move too long (-5326.625mm vs 101.000mm)
2025-08-18 19:28:23,729 - Changing monitoring state from "Printing" to "Cancelling"
2025-08-18 19:28:23,821 - Recv: ok
I tried with relative and absolute extrusion.
Curiously, after resetting Klipper, the gcode file runs fine.
Just a guess, it seems that you use G90, so if the E axis was not at zero, the G1 E5 F250 would cause an excessive move
Like:
  • (G91) E0 → E5 (+5)
  • G90 E100 → E5 (-95)
Also, it seems that under normal printing, you do use the G92 to reset the position eventually, but there is no such command right before the test.
I thought that too.
Actually G90 is set quite at the start of the gcode file.
I may set a G92 E0 just before the G1 E5 F250 and give it a try.
But that does not explain why it runs fine under normal conditions.
Ad the deviation is quite excessive: Over 5 metres retraction?
Obviously the G92 E0 did the trick.
Thanks for leading the way.
