I have been having problems for 3 months with a recurring GSTAT Error, mostly on the extruder, rarely on Z1. The error often occurs during the skirt or when the nozzle moves to the park position at the end of printing. Sometimes also in the middle of the print.
So far I have tried:
-Different USB cables on the Pi
-Original Pi power supply
-Pi connection changed to Serial
-Different mainboards, both with onboard and with plug-in steppers
-various cables, original, accessories and crimped by myself
-Frame and stepper additionally grounded
-Various settings in Klipper
Current setup is a SKR-2 with BTT TMC5160 on a Hemera.
I hope you can help me, because I do not know what to do anymore.
Your tip was worth gold!
I added it to all the sections, but only when I added stealthchop in addition to the extruder section did it succeed.
Currently I have completed up to 12 hour prints.
Thanks for the crucial tip!
…not really sure how the dampening of the motor resonance (tpfd) would resolve a GSTAT 01 (reset) error?
For the 5160 the first ‘homing’ should be enough to self learn these settings which is the normal ops mode.
I had the same problem. The solution for me was to replace the extruder cable from the control board to the extruder motor with a pre-made from Amazon.
