Since the end of December my two printers have both been giving me the TMC ‘extruder’ reports GSTAT: 00000001 reset=1(Reset). Usually within the first couple of layers of the print. The documentation suggests either a wiring or voltage issue. Both machines were running a BTT octopus board with a 240W power supply. I have replaced the BTT TMC2209 stepsticks on each machine several times and replaced the extruder stepper motors. I have upgraded the power supplies to a 350W unit and recently went from the BTT octopus board to a BTT octopus pro board. Replacing the main board seemed to help one of the printers but the other printer is still giving me the extruder reset issue. Looking through some of the other threads I tried setting stealthchop_threshold = 0, replacing the usb cable, swapping out the raspberry pi, and setting microsteps = 16. I usually run with the Fluidd interface but I tried Mainsail also. Nothing made a difference.
After the reset, these were my values from the tmc dump:
dump_tmc stepper=extruder
========== Write-only registers ==========
SLAVECONF: 00000200 senddelay=2
IHOLD_IRUN: 00081616 ihold=22 irun=22 iholddelay=8
TPOWERDOWN: 00000014 tpowerdown=20
SGTHRS: 00000000
========== Queried registers ==========
GCONF: 000001c4 en_spreadcycle=1 pdn_disable=1 mstep_reg_select=1 multistep_filt=1
GSTAT: 00000000
IFCNT: 0000000f ifcnt=15
OTP_READ: 0000000f otp_fclktrim=15
IOIN: 210000c1 enn=1 pdn_uart=1 step=1 version=0x21
FACTORY_CONF: 0000000f fclktrim=15
TSTEP: 000fffff tstep=1048575
MSCNT: 00000198 mscnt=408
MSCURACT: 01380092 cur_a=146 cur_b=-200
CHOPCONF: 24030053 toff=3 hstrt=5 tbl=2 vsense=1 mres=4(16usteps) dedge=1
DRV_STATUS: 80160000 cs_actual=22 stst=1
PWMCONF: c80d0e24 pwm_ofs=36 pwm_grad=14 pwm_freq=1 pwm_autoscale=1 pwm_autograd=1 pwm_reg=8 pwm_lim=12
PWM_SCALE: 00000019 pwm_scale_sum=25
PWM_AUTO: 00100024 pwm_ofs_auto=36 pwm_grad_auto=16
SG_RESULT: 00000010 sg_result=16
I have attached the klippy log in case it shows anything beyond the reset. The picture shows the first two layers of a print that failed. The print quality is not very good and that to me would indicate it really is a hardware issue. Maybe try a something other than the BTT stepstick?
Thanks for any help.
