XoBoR
October 29, 2021, 1:09pm
1
Hi guys,
for a few days now my previously working printer stopped working with the Error in the title.
The error seems to happen primarily but not only on long y moves.
I’ve tried to increase the run_current value, decrease movement speed, with no success.
I’ve tried switching the stepper drivers, the cables and the motor itself, but the error persists.
The stepper for which the error is reported varies from x, y, z and z1, never extruder though.
I guess this is somehow related to the new TMC Driver Error checking in V0.10.XXX?
I’m running a BTT Skr E3 Turbo in this printer.
klippy.log (312.5 KB)
Any Ideas on what I could try next? Im really out of ideas!
Sineos
October 29, 2021, 3:48pm
2
XoBoR
October 29, 2021, 4:50pm
3
That seems to be a different problem. I tried everything mentioned, including changing the stepper, and that didn’t work for me.
The run_current for the y-axis with 2A is quite high. TMC2209 limit is 1.7A
Do the steppers have passive and active cooling?
As @EddyMI3D noted, your run_current is too high for that driver. A TMC2209 on a stepstick will not handle 2A even with good active cooling. The chip itself is rated for 2A, but there’s not enough copper on a stepstick board to sink that much heat.
XoBoR
October 29, 2021, 11:29pm
6
They have active cooling.
The high run_current value was just to test if the error is related to a too low value.
XoBoR
November 6, 2021, 7:53pm
7
So in the Meantime I bought a new 24V Meanwell PSU to replace the original 12V one, didn’t help.
Then i bought a new board (same one), and even that didn’t help.
I also completely changed the wiring, needless to say, it also didn’t help.
I have no ideas left, does no one have an idea what might be causing this?
When I do DUMP_TMC after the error happens, I can see that ALL of the drivers have the reset flag set. Maybe that helps?
I assume you have TMC2209 drivers to put into the slots of the board.
And I assume that the drivers are correctly setup for UART mode.
Sineos
November 6, 2021, 8:36pm
9
XoBoR
November 7, 2021, 9:58am
10
The E3 Turbo comes with pre-soldered TMC2209 drivers…
DiNGBaT
December 7, 2021, 5:07pm
11
‘driver_tpfd: 0’ in the stepper config worked for me.
[tmc5160 stepper_x]
cs_pin: PC14
sense_resistor: 0.075
interpolate: True
run_current: 1.28
#hold_current: 1
#stealthchop_threshold: 501
spi_software_mosi_pin: PG15
spi_software_miso_pin: PB6
spi_software_sclk_pin: PB3
driver_tpfd: 0
Hi, did you figured out a solution, or what caused the issue?
XoBoR
January 30, 2022, 7:55pm
13
Nope, I did not, but I was able to return the Board and got my money back…
In one of the recent Klipper updates the recommendation regarding setting a hold_current for TMC drivers changed, I thought this might be related to this issue. But since I dont have the board anymore I couldn’t test it.
XoBoR
January 30, 2022, 7:58pm
14
There are also 2 threads on the Github of the E3 Turbo:
opened 03:25PM - 20 Nov 21 UTC
Why, always geting this... either it is on Z or E or Y, seems random. But same e… rror... so sick of it. So much wasted print time and plastic!!
Two brand new ender 5 plus with klipper, and two new E3 turbo cards.
Have tried to change driver, cable, stepper motor, added extea ground wire to psu, but nothing helps...
Running klipper
Just about had enough of this now.
opened 08:46AM - 26 Oct 21 UTC
Hello, I am retrofitting an SKR e3 turbo on a Chiron 3d printer. I am randomly g… etting
On klipper:
“TMC ‘stepper_z’ reports error: GSTAT: 00000001 reset=1(Reset)
it freezes and asks for firmware_restart.
(that could report after a reset on any other axis, and usually happens when it is in G1)
for sanity check I flashed marlin and on Marlin the behaviour is different. No faults are reported , it doesn't freeze but it doubles the distances.
When using Klipper, the rpi is connected on the usb port and not uart , but when using Marlin, nothing is connected to the usb port.
But no solutions there either.
Same issue. Just updated klipper literally a few hours before it started happening. Pretty much a brand new build and i am 100% CERTAIN that there is no loose connectors or bad connections (i am a auto electrician by trade). So definitely a firmware problem. Could the devs look in to this issue at all? Its holding me up now… btw mine is saying stepper Y
What does this do?
Did see it mentioned on the Klipper website, but not under the 2209 driver section tho.
