Ez/ tmc5160 running hot even on idle
Basic Information: sometimes at start up steppers are 50+ deg
Printer Model: ender 3 (stock motors)
MCU / Printerboard: e3ez (48v on x and y)
Host / SBC CB1
installed an e3ez board with a CB1 on an ender 3 since im trying to convert it to an enderwire later on, 48v on both X n Y
lowered the run_current to 0.5 but the tmc5160 steppers are running hot compared to the 2209 and I thought they’ll be running cooler than the rest …
not all the time but most of the time can’t even touch them for a while, so put thermistors and they running 50+ sometimes and 35-40 at start up and not sure what’s the issue, the motors aren’t running hot per say but the steppers … and affraid it’ll make them brake or something
thanks for any help or guidance ˆˆ
klippy.log (508.3 KB)
You should attach your klippy.log as advised by the template.
Otherwise nobody can check your current config and point towards any issues in there.
yes thank you … done now
tried to attach before and it didn’t work nor let me put more than one pic ˆˆ
cheers
Yeah that is a spam restriction for new users.
Hm do you actively cool the stepper drivers?
Stealthchop at least causes more motor heat than SpreadCycle but i never checked my drivers.
Current seems to be reasonable for the printer.
Check with SpreadCycle and interpolate: true for testing purpose.
just the stock ender 3 electronics case for now, as the conversion to an underwire didn’t really start yet
also that’s how I was running it and sometimes its 50+ deg and for now its 45± on idle whilst
Laos tried with the interpolation off and increased the steps to 128 and same thing
[tmc5160 stepper_x]
cs_pin: PB8
spi_software_miso_pin: PC11
spi_software_mosi_pin: PC12
spi_software_sclk_pin: PC10
diag1_pin: ^!PC4 #^PF3
interpolate: True
run_current: 0.5
hold_current: 0.150
sense_resistor: 0.075
stealthchop_threshold: 999999
driver_SGT: 0
