Firmware error after EMMC install
Printer Model: orangestorm giga
MCU / Printerboard:
I installed a new EMMC in my giga, and while I can connect to it with mainsail or fluidd, the printer screen just shows the logo, and I have a firmware error showing in the web interface. Sorry i don’t have access right now to pull the logs, and I am doing this from my phone so I can not attach a zip. I did copy the error section and emailed it to myself before leaving the office. I will paste that. Sorry I wasn’t able to fully follow the instructions.
Extruder max_extrude_ratio=207.875844
mcu ‘mcu’: Starting CAN connect
Created a socket
mcu ‘mcu’: Unable to open CAN port: Failed to transmit: [Errno 100] Network is down
webhooks client 281473719928528: New connection
webhooks client 281473719928528: Client info {‘program’: ‘Moonraker’, ‘version’: ‘v0.9.2-0-gb40751b’}
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
Created a socket
MCU error during connect
File “/home/mks/klipper/klippy/mcu.py”, line 787, in _mcu_identify
self._serial.connect_canbus(self._serialport, nodeid,
File “/home/mks/klipper/klippy/serialhdl.py”, line 133, in connect_canbus
self._error(“Unable to connect”)
File “/home/mks/klipper/klippy/serialhdl.py”, line 61, in _error
serialhdl.error: mcu ‘mcu’: Unable to connect
File “/home/mks/klipper/klippy/klippy.py”, line 131, in _connect
self.send_event(“klippy:mcu_identify”)
File “/home/mks/klipper/klippy/klippy.py”, line 223, in send_event
return [cb(*params) for cb in self.event_handlers.get(event, )]
File “/home/mks/klipper/klippy/mcu.py”, line 798, in _mcu_identify
raise error(str(e))
mcu.error: mcu ‘mcu’: Unable to connect
Error configuring printer
I had that same error while trying to install EBB42 CAN. The solution that I found was to write the following command in the pi console (via SSH):
sudo ip link set up can0 type can bitrate 500000
In my case, the problem was that the speed of CAN was not properly set.
Thanks! I Found out there are other issues too. Firmware isn’t fully set up.
