$FIRMWARE_RESTART when starting 4Max Print
Printer Model: Elegoo 4 Max
Slicer - Orca Slicer
Need help now that I can’t print with usb or WiFi
Printing start causing restart, looks like it’s a command under “console” when the printer is selected
USB happens right away
WiFi start causes system to go home preheat and then commands restart
Printer and Orca have everything updated
Will not print anything now but ran 3 small prints this morning while tuning new material
Klipper Load spikes to 160% when it happens
Thank you for your help
klippy.log - From Start - Pasted:
15:08:03
FIRMWARE_RESTART 15:08:19 // Klipper state: Ready 15:08:24 SET_GCODE_OFFSET Z=-1.840000 MOVE=0
15:08:24
BED_MESH_CLEAR 15:08:24 BED_MESH_PROFILE load=11
15:08:25
M84 15:08:25 BED_MESH_CLEAR
15:08:25
BED_MESH_PROFILE load=11 15:08:27 SAVE_VARIABLE VARIABLE=was_interrupted VALUE=False
15:09:21
FIRMWARE_RESTART 15:09:22 // Klipper state: Disconnect 15:09:26 // Klipper state: Ready 15:09:31 SET_GCODE_OFFSET Z=-1.840000 MOVE=0
15:09:31
BED_MESH_CLEAR 15:09:31 BED_MESH_PROFILE load=11
15:09:32
M84 15:09:32 BED_MESH_CLEAR
15:09:32
BED_MESH_PROFILE load=11 15:09:37 SAVE_VARIABLE VARIABLE=was_interrupted VALUE=False
15:15:56
FIRMWARE_RESTART 15:16:01 // Klipper state: Ready 15:16:06 SET_GCODE_OFFSET Z=-1.840000 MOVE=0
15:16:06
BED_MESH_CLEAR 15:16:06 BED_MESH_PROFILE load=11
15:16:07
M84 15:16:07 BED_MESH_CLEAR
15:16:07
BED_MESH_PROFILE load=11 15:16:12 SAVE_VARIABLE VARIABLE=was_interrupted VALUE=False
15:58:38
$ FIRMWARE_RESTART
15:58:53
OK… new update. Thought to try another file from this morning and the pressure advance test starts just fine… the retraction test will not work and overloads klipper, however.
Thoughts?
  1. The template you ignored is there for reasons. See How-To Ask for Help
  2. This printer uses a modified Klipper version that we do not support. Please revert to Elegoo for further help
