Firmware retraction is slow moving, slicer or klipper problem?
Printer Model: Ender 5 Pro
MCU / Printerboard: BTT SKR Mini e3 v3
klippy.log file too big, 29 mb? is this the root to the whole problem? something nasty happening?
Hey guys! Polymer Engineer from sweden here!
What an awsome firmware to begin with! But ive encounter something strange i couldnt fix, i was first using Cura, but to get firmware retraction to work without addons/plugins i switched to SuperSlicer, ive turned of everything i can find that is doing any auto speed thing in the slicer to make Klipper take care of things. X Y movements is really solid and works really good, but the firmaware retraction is working but it retracts so slow!
6mm retraction at 100mm/s speed takes 4-5 seconds, so something is of but i cant find where..
I can uploead klippy to google drive if needed, it was too big for forum, 29mbv ;o
Best regards!
/Peter
A klippy.log would help since it contains the interpreted config that you are using. You either can zip it, upload it to gdrive.
The settings that limit retraction velocity are:
#max_extrude_only_velocity:
#max_extrude_only_accel:
#   Maximum velocity (in mm/s) and acceleration (in mm/s^2) of the
#   extruder motor for retractions and extrude-only moves. These
#   settings do not have any impact on normal printing moves. If not
#   specified then they are calculated to match the limit an XY
#   printing move with a cross section of 4.0*nozzle_diameter^2 would
#   have.
And if you are using firmware retraction (G10/G11):
[firmware_retraction]
#retract_length: 0
#   The length of filament (in mm) to retract when G10 is activated,
#   and to unretract when G11 is activated (but see
#   unretract_extra_length below). The default is 0 mm.
#retract_speed: 20
#   The speed of retraction, in mm/s. The default is 20 mm/s.
#unretract_speed: 10
#   The speed of unretraction, in mm/s. The default is 10 mm/s.
https://www.klipper3d.org/Config_Reference.html#extruder
use a number that is sane for your situation
max_extrude_only_accel: 5000
You sir should be awarded an gold medal and an high five, i feel so stupid! Ofc i need to define more movement if i klipper should do the movement instead of the slicers “assumptions”…
I went with
max_extrude_only_velocity: 60
max_extrude_only_accel: 1500
and now it works flawlessly, had even to turn down ret-speed to 40 whilst printing to not slip grip on filament!
Is there any deeper math or study to find best accel speed?
Cant thank you enough i was so sure it was some slicer setting so this would taken ages!
Just look at the progress, now i was able to print my bracket no problems at all at speeds i didnt think was possible with bowden with this quality :muscle:
