Printer Model: Flashforge Creator 3
MCU / Printerboard: SKR pro v1.1
Host / SBC: pi 3b
My Question:
Just in progress of bringing old printer back to life. Found some posts from user retnel, seems he has done nearly the same. Would be perfect if camera wiring and config could be shared. @retnel is your creator printing and could you assist?
Just put components in compartment and doing wiring. Klipper is prapared but default config and first IDEX. Next week final assembling of new hotends and ready to move
Made good process.
Installed hotends and EBB 42s, wiring to thermistor, temp sensor, limit switch, piezzo board still undone.
Wired up cabinet components and EBBs
Installed Klipper, flashed board and CAN components.
Adapted Camera and USB socket. Measured USB socket to connector and created adapter. Same is working for Camera. Conclusion: Pin assignment for cam and socket connector is same, colors differs.
Next estimated steps:
Create initial printer cfg, install drivers, check steppers, wiring up the rest, check switches, sensors, heaters, piezzos and implement macros.
