Follow the disconnections... Ideas?
Printer Model:
MCU / Printerboard:
after managing to install the EBB42 by CAN, before I had it by USB… I thought that the disconnections were over… but no… When changing to Fluidd, I receive another message, which I don’t know if it will be similar who received before…
I enclose a copy of the message and a copy of the log.
I have to say that I have been able to finish some impressions, less than 1 hour… and that these failures are usually at the beginning of the impression, sometimes I have had them before starting, while I am doing the Tilt adjust…
klippy (2).log (5.6 MB)
I have to say that I have a baud rate of 500,000, when they recommend 250,000
MCU ‘EBBCan’ shutdown: Missed scheduling of next digital out event
This is generally indicative of an intermittent
communication failure between micro-controller and host.
Printer is shutdown
this morning i have place a post with a issue with EBB42 v1.1… think remeber that these board uses these Chip…
In this moment i have installed firmwares:
  • Octopus pro: v0.10.0-588-g51da02b7
  • EBB42v1.1: v0.10.0-591-ga2482d4f
EBB42v1.1, its affected for the explained in post?
Is there any other way to update Klipper on the EBB42 other than using a USB cable and STM32?
Thx
Try this if you haven’t already:
sudo nano /etc/network/interfaces.d/can0
Change auto can0 to allow-hotplug can0
Save and reboot
now I’m in an impression… we’ll see if it ends.
Out of curiosity, what does that line do?
That if you disconnect… you can reconnect and hopefully continue?
Yep, hot plug is what you think.
Is there a way to see if there has been a disconnection? Maybe some message in the console or looking for something in the log?
You can test the bus but not the disconnects that I know of.
sudo apt-get install can-utils
Run cangen
Then open a second ssh terminal and run ifconfig
Look at packet loss and errors for can0 note these numbers. Wait for a few minutes and run ifconfig and check to see if those have increased; if so, there might be a connection, termination, or interference.
If those numbers haven’t changed then you might be able to run at a faster bitrate.
Also, in your /etc/network/interfaces.d/can0
If txqueuelen is less than 1024 the change it to 1024, this is the buffer setting.
It sounds to me like I tried this, or something similar… and it gave me an error… but tomorrow I’ll try again…
one thing that I’ve changed in can0, is the value of txqueuelen that I had at 128…
I just finished a short impression about 35 min, and everything went well…
edit
Try find the limit…
