Geeetech a10t and klipper
I have the raspberryPhi running… If I look with my browser I find Fluidd…
I made the hex file, and upload it to my printer… after that, if I restart the printer then display is not working anymore… so thats good there is other firmware in it…
later I upload the firmware for the geeetech A10T V4.1 again, after that the display was working again… so I think change the firmware went also okay…
but , with the hex file made with * cd ~/klipper/ make menuconfig is maybe not okay with my printer?
but I don’t know what need…
the mainboard in the Geeetech A10T is a GT2560 V4.1 so I did choose in the klipper Firmware Configurator
micro controller architecture (Atmega AVR)
processor model atmega2560
Processor speed 16Mhz
communication interface (UART0)
(250000) baud rate for serial port…
but I don’t know where to found the info so I know for sure it is okay?
Klipper /out/ has the files Klipper.elf.hex
klipper.elf
and klipper.dict
I use Klipper.elf.hex ?
but if I use the klipper hexfile, and I open Fluidd in my browser i see this:
Option ‘default_parameter_x’ is not valid in section ‘gcode_macro pause_macro’
Once the underlying issue is corrected, use the “RESTART”
command to reload the config and restart the host software.
Printer is halted
so thats in the printer.cfg file? but is the hex file okay?
