General understanding what the value of tap_z_offset does
Printer Model: voron 2.4 with eddy duo
MCU / Printerboard: BTT octopus MAX EZ
Host / SBC: raspberry pi 5
i want to know if what i think the tap_z_offset should do is also wat the code in klipper is doing. what i see is the opposite behavior.
so during final step of calibrating my eddy probe i also calibrated the tap_z_offset using the paper test.
i heated the nossle to 125 degrees and the bed to 60 and let it heatsoak.
i then lowered the nossle onto the paper until it you can feel resistance on the paper.
after that i remove the paper and issue the command Z_OFFSET_APPLY_PROBE METHOD=tap.
it taps the bed and gives a value (in my case 0.250) and i save the value.
what i think what klipper is doing is setting a negative offset to 0. 0 should be the paper and -0.250 should be the tap on the bed. so when a tap is preformed like say at 0.2 the actualy 0 value should be 0.250 higher at 0.450 because of the paper?
yet i see it the other way around. i see after de bedmesh etc the nossle scrapping the bed with tap_z_offset=0.250 and with 0 its not doing that, it prints perfectly.
so im trying to understand what the value tap_z_offset actually does. what does it offset from where to where
tap_z_offset is intended to cancel “bias”, that is it.
For whatever reason(s), tap may detect zero repeatedly, but with a “constant” offset.
This “constant” offset can be canceled with tap_z_offset.
There is no built-in helper to do a paper test for the tap, and by so, to call a manual probe test.
Where I would expect that offset is within -0.1..0.1 normally, so it is hard to get it “right” with the paper.
My personal example is tap_z_offset = -0.085
Otherwise, the intended way to do so may look like that:
SET_Z_FROM_PROBE MEHTOD=tap
BED_MESH_CALIBRATE ADAPTIVE=1 METHOD=tap
<print first layer + babby stepping>
Hope that helps,
-Timofey
  1. Eddy: compensate bed_mesh with tap
Hi, it helps to understand it.
so from the use SET_Z_FROM_PROBE MEHTOD=tap is then stating 0 = bed.
i was under the understanding that Z_OFFSET_APPLY_PROBE METHOD=tap would also use the bed as a some sort of 0 reference. but its not.
its using the stored G28 Z reference as absolute 0 which is why i get strange values.
my G28 reference is a sensor where the nossle is touching (voron 2.4 has a sensor at the back) this is a rough Z, because of thermal expension etc the bed may be higher
for the bedmesh i use the bedmesh parameter zero_reference_position: 175, 175 and do then a probe on that position and then say this is Z= 0. might change that to this SET_Z_FROM_PROBE MEHTOD=tap seems allot easier.
