Printer Model: Anycubic kobra 2 neo
MCU / Printerboard: Not sure, but microcontroller lablings are GD32F303 RGT6 klippy.logklippy.log (169.9 KB)
I use lts raspbian minimal installation on my board. Tried to search for this problem for 2 days straight. Everything works, except MCU. I get the same error everytime.
mcu 'mcu': Unable to open serial port: [Errno 13] could not open port /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0: [Errno 13] Permission denied: '/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0'
Second log:
mcu 'mcu': Timeout on connect
MCU error during connect
serialhdl.error: mcu 'mcu': Unable to connect
Which would indicate that the board is not correctly flashed. Check with How-To Trouble-Shoot to see if and how the board registers to the Linux OS
As for the Kobra 2 Neo, I would not be aware of an existing config file and build instructions, so I do not know on which reference you build it.
From your log
========= Last MCU build config =========
CONFIG_LOW_LEVEL_OPTIONS=y
# CONFIG_MACH_AVR is not set
# CONFIG_MACH_ATSAM is not set
# CONFIG_MACH_ATSAMD is not set
# CONFIG_MACH_LPC176X is not set
# CONFIG_MACH_STM32 is not set
# CONFIG_MACH_HC32F460 is not set
# CONFIG_MACH_RP2040 is not set
# CONFIG_MACH_PRU is not set
# CONFIG_MACH_AR100 is not set
# CONFIG_MACH_LINUX is not set
CONFIG_MACH_SIMU=y
CONFIG_BOARD_DIRECTORY="simulator"
CONFIG_CLOCK_FREQ=20000000
CONFIG_SERIAL=y
CONFIG_SIMULATOR_SELECT=y
CONFIG_SERIAL_BAUD=115200
CONFIG_USB_VENDOR_ID=0x1d50
CONFIG_USB_DEVICE_ID=0x614e
CONFIG_USB_SERIAL_NUMBER="12345"
CONFIG_WANT_GPIO_BITBANGING=y
CONFIG_WANT_DISPLAYS=y
CONFIG_WANT_SENSORS=y
CONFIG_WANT_LIS2DW=y
CONFIG_WANT_SOFTWARE_SPI=y
CONFIG_CANBUS_FREQUENCY=1000000
CONFIG_INITIAL_PINS=""
CONFIG_HAVE_GPIO=y
CONFIG_HAVE_GPIO_ADC=y
CONFIG_HAVE_GPIO_SPI=y
CONFIG_HAVE_GPIO_HARD_PWM=y
CONFIG_INLINE_STEPPER_HACK=y
These make menuconfig parameters definitively are wrong, but since I do not have better ones, I cannot provide further guidance.
Ok, i was not sure about klipper, cause flashing my very new 3d printer is pretty scary. But now i think that i could try. I have read discussions about installing klipper on the board with the same microcontroller as mine (here) but i am not sure how to do it properly. Do you have any instructions for configuring and flashing a firmware to my board?
Thank you in advance for any help.
Ok. I tried flashing it with SD card by putting firmware.bin file on it but after several tries of powering on and onn my printer doesnāt flash.
I tried flashing it with ānormalā method in kiauh but got this error:
Failed to flash to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0: Error running dfu-util
If the device is already in bootloader mode it can be flashed with the
following command:
make flash FLASH_DEVICE=1eaf:0003
OR
make flash FLASH_DEVICE=1209:beba
If attempting to flash via 3.3V serial, then use:
make serialflash FLASH_DEVICE=/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
make: *** [src/stm32/Makefile:111: flash] ŠŃибка 255
I am pretty much stuck. Can you help me with that, please?
zamonary1@orangepi3-lts:~/klipper$ make flash FLASH_DEVICE=/dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Flashing out/klipper.bin to /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Entering bootloader on /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
Device reconnect on /sys/devices/platform/soc/5101400.usb/usb5/5-1/5-1:1.0/ttyUSB0
sudo dfu-util -p 5-1 -R -a 2 -D out/klipper.bin
dfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
dfu-util: No DFU capable USB device available
following command:
OR
iām really frustrated because i just cannot make this work. The board constantly boots to marlin instead. I reformatted the sd card 2 times and it gave me nothing. I gues iāll go and rest a little.
Ok. I got in contact the anycubic support. They said that installing klipper on my printer will ruin the official warranty and sent me the only official firmware that they currently have. I think i should share it to you guys and other people looking for anycubic kobra 2 neo firmware. Link to google drive that they sent to me (click)
??? Did they say why it would void the official warranty?
I would think that the only (valid) reasons for making a statement like this is because there is danger of damaging the product or could cause personal harm to the user.
I would suspect that they are making this statement because they donāt want to support Klipper but what level of support do they give if you want to do something like add a filament runout sensor, which would require a firmware change or wanted to change the print surface.
idk, i suggest that kobra 2 neo is unpopular model and this raises a problem with making configs and testing them. I really want to get klipper working on my board but iāve never used it before. If you have any ideas then please let me know.
