GPIO 3.5" klipperscreen on SSH theme help me
I’m installing klipperscreen, I use pi 3b and 3.5 lcd with gpio plug, I installed klipperscreen via Kiauh, installed lcd show, but the klipper interface does not appear, instead it shows the interface as in the picture
I don’t know for sure but I expect the GPIO interface only supports text (ASCII) and not bit addressed graphics. Klipperscreen is a Graphical application.
Does your display have any other inputs?
no, i use the code screen as picture, i watch on youtube and other sites and see they can do it
Welcome Saitoryu,
when asking a question here, please do…
  1. If you have a klippy.log, post it
  2. Be very specific, telling/explaining your problem (pictures, schematics, etc…)
I tried a display like that around 2022. Worked flawless with an RPi 4. There should be no problem with an RPi 3 or 5. Touch was working also. I found all needed information to get it working in the www.
KlipperScreen claims. “KlipperScreen should run on any touchscreen that you can connect to a host (Raspberry, PC, Tablet)” KlipperScreen
So…
