GPIO pin assignment
[ Voron 0.2] Printer Model:
[MP4 + CM4
logs-20241008-233612.zip (82.6 KB)
] MCU / Printerboard:
[uploaded
] klippy.log
Hello, I have a Voron Trident and managed to set up some additional fans via the GPIO pins..
I also have a V0.2 with a CM4 and tried to make use of the GPIO pins there for a servo to add a nozzle cleaner.
However, I can’t get rid of the error with Pin must be specified.l
I’ve attached I believe necessary screen shots and hope someone can see the error I’m making.
Thanks in advance.
Obviously. There is nothing in that macro:
[exclude_object]
[servo NozzleBrush]
serial = /dev/serial/by-id/usb-Klipper_stm32g0b1xx_1E0017001450415833323520-if00
https://www.klipper3d.org/Config_Reference.html#servo
Yep… assigned the wrong file name…DUH!!
