Hangs at Klipper reports startup
Printer Model: Custom made cartesian
MCU / Printerboard: BTT SKR2 to raspberry pi to hermit crab in can mode
serial: /dev/ttyAMA0
[mcu rpi_mcu]
serial: /tmp/klipper_host_mcu
[mcu hermitcrab_mcu]
canbus_uuid: c**********9
upload.log (146.8 KB)
Log file contains: klippy.log-klipperscreen.log-moonraker.log
Loads all the way to blue screen “Klipper reports: STARTUP” and hangs there, i believe connection issue is with moonraker on localhost 127.0.0.1. If i go to 192.168..(local network ip):7125 i get…
Any Insight as to the Damn hold up here would be greatly appreciated as i have been working on this for over week now.
Install was with Kiauh, i have tried uninstalling then reinstalling moonraker/klipper/klipperscreen/ manually from scripts folder. I have tried ./set-policykit-rules.sh
Your log file suggests that your klipperscreen config file is invalid and contains no section headers. Did you set it up properly?
It was just reinstalled so prolly not. Uninstalled to verify problem sstill exissted without it
I’m not understanding the problem then. Klipperscreen is the only frontend you mentioned. If you’ve uninstalled it, what is the problem and how are you verifying it exists?
i have mainsail, everything has been installed via kiauh. Here is the screen where it hangs.
I’m not even sure where to begin. It doesn’t look like you have a full klippy.log, just your config file, which is full of complex macros. The moonraker and klipperscreen logs are full of errors. I’d suggest starting with a clean MainsailOS install and get a basic printer config up and running properly before adding complexity.
The errors in the upload.log start with:
(Have you put them all together? Zipping the files would keep the overview)
File contains no section headers.
Issues with Moonraker:
2023-03-09 12:45:48,113 [KlippyWebsocket.py:on_open()] - Moonraker Websocket Open
2023-03-09 12:45:48,183 [KlippyRest.py:send_request()] - Sending request to http://127.0.0.1:7125/server/info
2023-03-09 12:45:48,234 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/machine/device_power/devices
2023-03-09 12:45:48,260 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/printer/info
2023-03-09 12:45:51,882 [KlippyRest.py:send_request()] - Sending request to http://127.0.0.1:7125/server/info
2023-03-09 12:45:51,908 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/machine/device_power/devices
2023-03-09 12:45:51,930 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/printer/info
2023-03-09 12:45:54,871 [KlippyRest.py:send_request()] - Sending request to http://127.0.0.1:7125/server/info
2023-03-09 12:45:54,892 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/machine/device_power/devices
2023-03-09 12:45:54,908 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/printer/info
2023-03-09 12:45:57,871 [KlippyRest.py:send_request()] - Sending request to http://127.0.0.1:7125/server/info
2023-03-09 12:45:57,890 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/machine/device_power/devices
2023-03-09 12:45:57,908 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/printer/info
2023-03-09 12:46:00,873 [KlippyRest.py:send_request()] - Sending request to http://127.0.0.1:7125/server/info
2023-03-09 12:46:00,891 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/machine/device_power/devices
2023-03-09 12:46:00,911 [KlippyRest.py:send_request()] - 404 Client Error>>Not Found for url>>http://127.0.0.1:7125/printer/info
2023-03-09 12:55:27,487 [KlippyWebsocket.py:on_close()] - Server Shutdown
And a lot of issues at the end of that file - from where they ever come.
If you were using SKR2 main board with PI and BIQU Hermit Crab in Canbus mode how would you connect skr board to raspberry pi? I.E. what pins/protocall
BTW thx for the quick response that I recieved!
Can you share the answer? I also use an SKR2.
Thanks.
hcet14, Id be more then happy to share the answer once i finally get it completely figured out. Im close but not there just yet.
Why wouldn’t you just use USB?
