Help Klipper installation on ender 5 pro
FOR ANYONE WITH THIS PROBLEM:
I solved it by copying the config from klipper/config/generic-creality-v4.2.7.cfg at master · Klipper3d/klipper · GitHub to my printer .cfg (this is for 4.2.7 Creality board)
Im trying to install klipper on my ender 5 pro with a creality 4.2.7 and a linux pc runing debian. I was having trouble conecting it to marlin because i was mising the serial on the printer.cfg and fixed it. Now im conected to the printer, the board is flashed and the extruder and Heater Bed work perfectly but im getting the error: “No trigger on stepper_x after full movement” when trying to home. I added the position_min: line but nothing changed. I do hear a faint whining of the motor when running the STEPPER_BUZZ STEPPER=stepper_x but it doesnt really move. The printer with the marlin frimware works perfectly. link to the printer.cfg and klippy log: https://github.com/Tony-F42/Klipper-ender-5-pro-creality-2.4.7
Any help would be apreciated.
Hello @tony_goya !
Please upload the klippy.log here.
Welcome tony_goya,
you have basically the same problem as @Maniac here Ender 3v3 ke, ADXL345 on Type-C - #5 by hcet14 .
You may try the same command
ls /dev/serial/by-id/*
and post the output as text.
For more information use the org. Klipper docu. Installation - Klipper documentation and always Sineos Knowledge Base - Klipper .
