Position Endstop / Stepper Z
Printer Model: Ender5 Plus Modded
MCU / Printerboard: Pi 3B+
Describe your issue: I’m running Klipper for the first time on an Ender 5 Plus, BTT Skr 3 V3 board, Pi 3B+, MicroSwiss NG Revo and CR Touch. Error is Unknown Pin Chip Probe. Can anyone please share a working config file for this setup? I have tried various fixes, but no joy yet. Below is my .CFG content.
[include mainsail.cfg]
[crtouch]
sensor_pin: ^PC14"
control_pin: PA1
x_offset: -37.5
y_offset: -0.5
z_offset: 0
speed: 2.0
samples: 2
samples_result: median
sample_retract_dist: 6.0
samples_tolerance: 0.01
samples_tolerance_retries: 3
[safe_z_home]
home_xy_position: 175,175
Speed: 50
z_hop: 10
z_hop_speed: 5
[stepper_x]
step_pin: PB13
dir_pin: !PB12
enable_pin: !PB14
rotation_distance: 40
endstop_pin: ^PC0
position_endstop: 0
position_max: 350
homing_speed: 50
[tmc2209 stepper_x]
uart_pin: PC11
tx_pin: PC10
uart_address: 0
run_current: 0.580
stealthchop_threshold: 999999
[stepper_y]
step_pin: PB10
dir_pin: !PB2
enable_pin: !PB11
endstop_pin: ^PC1
position_endstop: 0
position_max: 350
homing_speed: 50
[tmc2209 stepper_y]
uart_pin: PC11
tx_pin: PC10
uart_address: 2
run_current: 0.580
step_pin: PB0
dir_pin: PC5
enable_pin: !PB1
rotation_distance: 8
#position_endstop: 0.0
position_max: 350
[tmc2209 stepper_z]
uart_pin: PC11
tx_pin: PC10
uart_address: 1
run_current: 0.580
step_pin: PB3
dir_pin: !PB4
enable_pin: !PD1
gear_ratio: 3:1
rotation_distance: 46
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PC8
sensor_type: Generic 3950
sensor_pin: PA0
control: pid
pid_Kp: 22.2
pid_Ki: 1.08
pid_Kd: 114
min_temp: 01
max_temp: 300
[tmc2209 extruder]
uart_pin: PC11
tx_pin: PC10
uart_address: 3
run_current: 0.650
[bed_mesh]
speed: 100
horizontal_move_z: 8
mesh_min: 50, 50
mesh_max: 330, 330
probe_count: 5, 5
mesh_pps: 2,2
fade_start: 1
fade_end: 10
fade_target: 0
[heater_bed]
heater_pin: PC9
sensor_pin: PC4
control: pid
pid_Kp: 690.34
pid_Ki: 111.47
pid_Kd: 1068.83
min_temp: 0
max_temp: 100
[heater_fan heatbreak_cooling_fan]
pin: PC7
[heater_fan controller_fan]
pin: PB15
[fan]
pin: PC6
serial: /dev/serial/by-id/usb-STMicroelectronics_MARLIN_STM32G0B1RE_CDC_in_FS_Mode_2078364F524E-if00
[printer]
kinematics: cartesian
max_velocity: 300
max_accel: 2500
max_z_velocity: 5
max_z_accel: 100
[board_pins]
aliases:
EXP1 header
EXP1_1=PB5, EXP1_3=PA9, EXP1_5=PA10, EXP1_7=PB8, EXP1_9=,
EXP1_2=PA15, EXP1_4=, EXP1_6=PB9, EXP1_8=PD6, EXP1_10=<5V>
Hi @Spino ,
Please attach the requested klippy.log to your next post.
klippy.log.zip (7.7 MB)
And please use the Preformatted text feature of the forum editor for posting code.
Flagging a post is not the correct way to end a thread.
Please write your solution in a new post and mark it as Solution.
