Printer Model: Anycubic Kobra Max V1
MCU / Printerboard: Trigorilla Pro A v1.0.4
Host / SBC: RPI 3B+ Mainsail
Hi all, new Klipper user here. Setup a Pi few days ago and got my KMax setup with a combo of 2 public configs. So far its been smooth aside from nozzle eating the bed, and ive read through several posts about my printer specifically, as well as reading the documentation on leveling and I just can’t figure out how to setup Z Offset.
Its still a stock printer, so strain gauge setup on probe. I do “probe_calibrate” and “bed_mesh_calibrate” and save, but even in between print jobs the nozzle still ends up pushing into the bed enough to not extrude at all, and Its just been a constant battle of calibration and Klipper seamingly forgetting what it was calibrated to.
I set both the [probe] z offset and “saved config” offset to 0 and figured out my Z needs to be around .95 or 1.0, but adjusting it to that during a print is still the only way ive been able to print.
Enter `PROBE_CALIBRATE’ from the Console input box and you should have something like the following with the “Manual Probe” window popping up:
Putting a piece of paper below the nozzle.
Moving the toolhead down until there is friction between the paper and the nozzle.
Click on ACCEPT
In the Console input box enter SAVE_CONFIG
The printer will reboot. If you look at your printer.cfg file, you’ll see a commented out area at the end of the file that looks something like:
This is a copy-paste of a old suggestion on the forum of the exact steps ive done, and offset looks correct in the config but it still seems off whenever I go to print.
While I looked into both of those links, It really wasn’t anything I haven’t already done.
Im now having to set Z offset in the negative numbers to get it to actually stick to the bed, Its just frustrating because it was working better in marlin.
What is it about my bed mesh that just isnt being accounted for during initial printing?
Its still stock, so its the built in strain gauge tap probe, and yeah variance is up to 1.6 now with my latest mesh reading. Part of that is def warped bed but that’s why im trying to get it dialed in to compensate.
From what I recall it actually did pretty good? Iv got a print going now but iirc the values last times were all within 0.0025 of the initial points.
Ill have to run it again to be sure, but I do recall being happy with the output the first time or 2 I ran that test
Ok but seriously guys. What the helly am I missing?? Every print starts either digging into the bed or recently its just floating mid air, and I have to drop the z offset a bunch to where it actually starts sticking, and then cancel and restart the print because half the first layer never touched the bed.
??? What even is this? Why does adjusting the offset do NOTHING?
This isnt looking good vs stock firmware.
